Author: Subject: fs - cortina uprights, hanns 6 point harnesses
madrallysport
posted on 29/7/11 at 01:10 PM Reply With Quote
Guys
I'm having a clear out i have two complete sets of cortina uprights, with calipers, in need of bit of clean up. £90 a set delivered to your door in the uk. (postage which is included is £27 pounds via courier)
I also have a pair of 6 point harnesses, these are still in date for racing / fia use til 2014, they are hanns type harnesses, so are designed to be used with hanns device only. They're made by TRS, red in colour and only used a couple of times £220 for the pair posted to you.
UNDERSTEER is when you hit the wall with the front of the car.
OVERSTEER is when you hit the wall with the rear of the car.
HORSEPOWER is how fast you hit the wall.
TORQUE is how far you take the wall with you.
