Trev Borg
| posted on 28/8/11 at 09:43 AM |
T16 engine / turbo etc
This is now taking up space in my garage
Rover T16 turbo engine
turbo
manifolds
gearbox
radiator
twin fans
ecu
alternator
£75 maybe?
I also have an LSD to fit the PG1 for £100
Before you judge a man, walk a mile in his shoes.
By that time, who cares.
You're a mile away, and you've got his shoes
big_wasa
| posted on 28/8/11 at 06:06 PM |
lsd
Is it a Torsen type A or B ? used or new and whats its history / from what ?
cheers
Trev Borg
| posted on 28/8/11 at 07:45 PM |
I'm afraid I do not know anything about it.
I bought it off flebay as a used torsion LSD to fit PG1 gearbox.
It has three window in the side with a pair of toothed barrels in each if that helps
| posted on 28/8/11 at 09:09 PM |
PG1 gearbox?
Trev Borg
| posted on 28/8/11 at 10:33 PM |
Rover PG1 gearbox
The Rover PG1 gearbox fitted to the K series Elise, was manufactured by Powertrain Limited (who have now ceased trading), is a five-speed constant
mesh gearbox, which employs helical gears for speed transmission and final drive. The transmission castings are full aluminium construction and all
other components optimised for improved weight (36kg dry). The gearbox can be supplied with either a standard open differential or a Limited Slip
Differential, presently Torsen.
Due to the modular design of the gearbox various final drive ratio and 1st to 5th gear ratio combinations have been used. Including both present and
past an overall total of 21 ratio combinations, 5 speedometer gear ratios; and 7 clutch levers designs for both hydraulic and cable operation can be
called on to ensure the customers requirements are met.
Trev Borg
| posted on 28/8/11 at 10:39 PM |
http://forums.mg-rover.org/showpost.php?p=1964410&postcount=4
shows mine to be the type A
