Throttle Body Vacuum Plenum Whatsits
Made from short lengths of -6 fuel rail.
Can be provided with as many vac take offs as you like within reason, but typically would include 4 ports to connect to the 4 throttle bodies, then 2
take offs, one for a MAP sensor and the other for a FPR. Fitted with a bracket for easy mounting to engine or firewall.
Normally fitted with 4mm hose fittings in all positions unless others are requested.
Will provide a smoother vac signal that just using vac hoses due to the volume inside the bore of the rail. Nice and neat too and match up with the
billet fuel rails.
I'll post some photos later in the week.
Again done at cost for Locostbuilders
£35 each
Sera
http://www.motosera.com
