Author: Subject: FS: 2 Cycles
rayward
posted on 17/9/11 at 01:18 PM Reply With Quote
FS: 2 Cycles
Scott Sportser P6 2009 Hybrid, hardly used 1 very small scratch on frame
i've changed the tyres/tubes for some thinner ones, but originals will come with the bike
£220
Specialized Hardrock 2010
again hardly used, as new condition
£220
cant remember exact frame sizes but i'm 5' 10" with 31" inside leg and both fit me fine
Ray
[Edited on 17/9/11 by rayward]
daniel mason
posted on 17/9/11 at 01:27 PM Reply With Quote
What size is the specialised mate? Also do you know the spec of front and rear mech, brakes, front shocks etc? Also what price are they new? Thanks
rayward
posted on 17/9/11 at 01:36 PM Reply With Quote
will have to check frame size when i get home, spec below
i paid £349 for it
hth
Frame:Specialized A1 Premium Aluminium, fully butted, reinforced disc mount, forged dropouts with replaceable hanger, disc onlyFork:SR Suntour SF8-XCT-V2, 80mm, One piece alloy lower, 28mm Hi-Ten stanchionsFront Derailleur:Shimano AltusRear Derailleur:SRAM X-4, mid cageShifters:SRAM X-3, 7-speed triggerChainset:SR SunTour, square taper splineChainrings:42t x 32t x 22t chainringsBottom Bracket:Sealed cartridge, square taperCassette:SRAM PG-730, 7-speed, 11-32tChain:KMC Z7 with reusable Missing LinkPedals:Composite cage and body, 9/16"Front Brake:V brake, alloy linear pull, 1pc. padRear Brake:V brake, alloy linear pull, 1pc. padBrake Levers:Alloy, linear pullHandlebars:Hi-Ten riser bar, 32mm rise, 640mm wideStem:Forged alloyHeadset:1-1/8" threadless, loose ballGrips:Specialized Enduro, dual compound KratonRims:Alex Z-1000, 26", alloy, single wall, 32hFront Hub:Forged alloy, double sealed, steel QR, 32hRear Hub:Forged alloy, double sealed, steel QR, cassette, 32hSpokes:stainlessFront Tyre:Specialized Fast Trak LK Sport, 26x2.0"Rear Tyre:Specialized Fast Trak LK Sport, 26x2.0"Tubes:Schrader valveSaddle:Specialized XCSeatpost:Alloy two bolt, 12.5mm offset, micro adjustSeat Binder:Alloy QR, nylon washerNotes:Chain stay protector, reflectors, clear coat, owners manualWeight:Approx. 30.31lbs (13.75kg) for the 13 Inch Size.
