Author: Subject: FS: Stuart Taylor Locost - updated ad+pics
rayward
posted on 6/10/11 at 02:30 PM Reply With Quote
Been told by my son, my last ad was"lazy" so heres a better one !
For Sale, almost completed Stuart Taylor Motorsport Locost
as supplied now by Aries Motorsport
Chassis and Running Gear
Stuart Taylor Motorsport Built SpaceFrame Chassis (built in Roll bar), and Front Suspension
All powder coated in black
Alluminium Floor, Bulkheads and Side Panels
Ford Cortina Front uprights/Brakes, Fully Rebuilt with New Bearings Joints , Seals, Discs and Pads
Ford Capri 2.8 Rear Axle with Limited Slip Diff, Drum Brakes Rebuilt New Cylinders+Shoes
Ford Sierra Steering Column + Tec Rac 2.2 Turn Quick Rack
Adjustable Twin Master Cylinder ,Bias Bar Pedalbox
Engine and Gearbox
Ford 1300 Crossflow engine (711M block) rebuilt with new shells/rings etc
5 Speed Type 9 Gearbox+New PropShaft and remote gear linkage to bring gearstick back.
Stainless Inlet Manifold Mated to Yamaha R6 Carbs/Fuel Pump
Megajolt 3D Mappable Ignition (built in Hard Rev Limiter and shift light option) using Ford EDIS and Coilpack
Stainless 4 into 1 Exhaust System
New Lighweight Odyssey Gel Battery+Holder
Battery Cut Off Switch
Alloy Header Tank and Breather Tank
Interior
Cobra Roadster 7 Seats, used but excellent condition with a couple of small marks
Sabelt 4 Point Harnesses
Carbon Effect Dash, with New Dials + Bright 6
Aeroscreen+New Side Mirrors
Exterior
Refurbished Ford RS 13” Alloy Wheels with New Yokohama Tyres
Stuart Taylor Fibreglass Body Work Set
New Rear Light Set.
Main Jobs Required to Finish
2 brackets need fitting for Handbrake Cable
Engine Bay Wiring needs completing (all there labelled up just needs trimming +connecting)
IVA Bonnet Catches Need Fitting (supplied)
Rear Boot Are Cover needs making and fitting
Trigger wheel+sensor need fitting to crank pulley
IVA Trim needs fitting to Front Supension Area
Buyer To Collect from Hull, you will need a trailer !
asking price is £2700 but will lsten to offers
cheers
Ray
[Edited on 6/10/11 by rayward]
HowardB
posted on 6/10/11 at 03:17 PM Reply With Quote
that is really nice,..... good luck with the sale
Howard
rayward
posted on 9/10/11 at 02:19 PM Reply With Quote
SOLD !
