needforspeed
| posted on 22/11/11 at 10:06 PM |
kawasaki zx9r c1 engine kit
kawasaki zx9r c1 1999 motor its only got approx 6000 miles on it from new so is just run in!
ive been running it in my mk indy r for around 500 miles now with 2 oil changes. the engines had larger jets fitted and a set up around 400 miles ago.
its had a new clutch set and basket 50 miles ago along with uprated barnet springs + new spark plugs at the same time. sellin this as a kit complete
with a custom labelled heatshrunk motorsport wiring loom with the resistors buit in (cost me alot), ecu, regulator, propshaft adapter, pipercross air
filter and mounting cradle so literally ready to mount up wire up and start up!!!
ive also converted the clutch to hydroulic using a brand new modified arm and slave cylinder so will include carbon fibre bracket (cost me £70 alone)
or you can always just change back to cable if you wish.
the only negative is on the overrun in 4th gear it sometimes bangs in and out which is perfectly drivable and if your bothered about fixing it all it
requires is a new dog for 4th gear around £50 from memory.
07947719580
needforspeed
| posted on 29/11/11 at 09:23 PM |
up
needforspeed
| posted on 5/12/11 at 09:10 PM |
and again!
