Author: Subject: haynes chassis complete for sale £50.18
jossey
posted on 28/11/11 at 10:46 AM Reply With Quote
Well i have a haynes chassis im selling. It was made by a local Fabricators then i added steel floor and rear into it. Ive cut away some of the tubes at the front ready for the bike engine cradle to drop in. And the front of the passenger footwell ive moved back to get the engine in close. it was built to take a V6 engine so is very stong and has a wide tunnel.
Needs a little bit of work to put back a few box sections if you want to fit a car engine in it.
It can be collected from my house in lincolnshire (near scunthorpe)
i know its a random amount too lol
David Johnson
carlknight1982
posted on 28/11/11 at 11:13 AM Reply With Quote
are the suspension brackets fitted? if so i'll take it.
Logic will get you from a A to B
Imagination will take you everywhere.
jossey
posted on 28/11/11 at 11:20 AM Reply With Quote
yes its been running with a pinto engine in it.
i got the chassis built and put a pinto in it then decided i wanted to go BEC which i did then i cut the engine bay to be wider which meant i removed the diagnal box section which the bottom of the pinto rested on. then started moving the passenger footwell back a bit.
needs painting again as i hammerited it last summer but its scuffed alot now.
David Johnson
carlknight1982
posted on 28/11/11 at 11:40 AM Reply With Quote
Ill take it then please, collection friday evening / weekend ok with you?
[Edited on 28/11/11 by carlknight1982]
jossey
posted on 28/11/11 at 01:43 PM Reply With Quote
either is fine :O)
David Johnson
NigeEss
posted on 28/11/11 at 08:04 PM Reply With Quote
Out of curiosity Jossey, why £50.18 ?
A case of why not ??????
jossey
posted on 28/11/11 at 08:23 PM Reply With Quote
Well nige I was
Going to put 50.44 but it seemed a bit too ermmmmm made up lol
David Johnson
eddie99
posted on 29/11/11 at 11:18 PM Reply With Quote
If anything falls though. I'll have it.
