Author: Subject: r1 and fireblade parts for sale
Dangle_kt
posted on 7/1/12 at 06:06 PM Reply With Quote
Doing a bit of a clear out - going on ebay if I get time but thought I'd list them on here in case there is interest from fellow locosters
r1 4xv
Stator and flywheel - £25
Clutch assembly inc baskets etc - no plates though as they were worn £25
Stator engine cover - £10
Clutch engine cover - £10
Crank £25
Cases - good numbers, bottom case perfect, top case has one or two small marks in one of the bores (may be useful for builds for engine mount points etc) - £25
Sump baffle plate - £5
Sump - £10
Oil pump £5
Uprated gearbox from 5jj - includes all parts to fit 4xv - £
Head - complete but a little beyond hope after a dropped valve head - some parts will be worth salvaging, maybe try out your porting skills before letting rip on your real head - but its for parts ONLY - £10
Fireblade - 900rr
Head but a little beyond hope after some foam plastic went down the intake and melted on one of the valves - maybe try out your porting skills before letting rip on your real head? £10
Shim buckets x16 - £1 each
Shims 190-180 in size £1 each
7 x inlet valves, complete with both springs, collet, retainer £2.50 each
8 x exhaust valves, complete with both springs, collet, retainer £2.50 each
inlet cam complete with sprocket £10
exhaust cam complete with sprocket £10
inlet cam retainer - £5
Exhaust cam retainer - £5
photos later.
Will go onto ebay, but will be more expensive to cover 10% ebay fees
sdh2903
posted on 7/1/12 at 08:40 PM Reply With Quote
How much for the 5jj gearbox?
Dangle_kt
posted on 7/1/12 at 08:45 PM Reply With Quote
To a locoster, £80 cash collected
Can post at cost if needed (I'll have to check Prices)
If posted id prefer money via bank transfer or if via PayPal youd need
To cover their stupid fees.
Dangle_kt
posted on 7/1/12 at 08:49 PM Reply With Quote
oh, and it would include the shift drum, shift mechanism, and engine cover - basically everything gear related to make sure you had all the parts needed to swap out your old gearbox.
Steve Hignett
posted on 7/1/12 at 08:55 PM Reply With Quote
Andy, http://www.parcelmonkey.co.uk for posting your gearbox etc.
If you do end up using it and need to log in to do the tranaction then send me a U2U and I'll reply with my username and password to save you all the reg. hassle etc...
Dangle_kt
posted on 7/1/12 at 09:01 PM Reply With Quote
Cheers steve - I've used "send it now" a few times, but its a bit pricey for a relatively small parcel!
Dangle_kt
posted on 7/1/12 at 11:26 PM Reply With Quote
R1 Parts listed on ebay now - see the link for photos.
Please u2u me if you are interested in anything, and I will do a deal outside of ebay
http://www.ebay.co.uk/sch/pootle2004/m.html
[Edited on 7/1/12 by Dangle_kt]
sdh2903
posted on 8/1/12 at 10:06 AM Reply With Quote
u2u re gearbox
