perksy
| posted on 21/2/12 at 09:38 PM |
Vauxhall XE Bottom End - Clearout Continues
Clearout in the garage continues
Have a Bottom end from an Early 'Round Tooth' version of the Vauxhall C20XE Redtop
This includes just about everything except the flywheel
The block and all the components (including the sump) have been cleaned and the block has been painted and had new core plugs fitted
It was then put back together (no oil seals fitted) and kept as a spare
(It turns over nice enough on the engine stand with a socket on the crank bolt)
Would make a nice base for a rebuild to perhaps a high spec' motor or just as a standard spare ?
Includes the crank, pistons & rods, front pulley, Oil pump & pick-up pipe, water pump and standard oil sump etc
Please note the water pump & oil pump might look new but they aren't
Don't have a clue what its all worth to be honest, so i'm open to offers before it goes on the bay of E or elsewhere
U2U if interested
laptoprob
| posted on 21/2/12 at 09:39 PM |
Perksy, someone is after a Coscast head on the wanted section.
thought i saw that you had one knocking about in the garage?
http://www.youtube.com/watch?v=ajlF4nWJtGA
perksy
| posted on 21/2/12 at 09:44 PM |
Hi Mate
Thanks for that i've sent him a U2U
Somebody else contacted me awhile back about one and i need to contact them aswell
perksy
| posted on 29/2/12 at 09:59 PM |
XE Bottom End now Sold
and on its way to South Wales
