Not Anumber
| posted on 14/5/12 at 11:33 AM |
MK Indy lightweight bonnet
MK Indy lightweight bonnet.
Exhaust cut out on the drivers side (Pinto/ Duratec side) otherwise plain panel in yellow with no central bulge or cut outs.
This is a very lightweigh panel which is great if you want to save on weight but dso thin it needs to be supported when it's off the car as it
has a tendancy to lose it's shape.
If you just wanted a standard bonnet it would be fine to use this and just beef it up with an additional thickness of matting on the underside.
Either way it's yours for £ 15 and a trip to sunny southend.
[Edited on 14/5/2012 by Not Anumber]
Not Anumber
| posted on 17/5/12 at 08:00 PM |
The Indy bonnet is 34 1/2 inches (87.5cm) long front to back measured either in the middle or along the long outside edges at the side.
The width (measured across the points where the edges touch the tops of the side panels) tapers from about 26 inches (66cm) at the front to about 38
1/2 inches (98 cm) by the scuttle.
If flattened into a flat sheeet it would measure 36 inches wide at it’s narrowest and 49" inches at it’s widest.
Not Anumber
| posted on 4/2/13 at 08:07 PM |
bump.
Still taking up space in the loft ifanyone is interested.
