JAG
| posted on 4/6/12 at 11:08 AM |
FS: Small Lathe
Hi All,
I've got a small lathe which I have no use for. I see some on here like this kind of thing so I thought I'd let you guys have a look. It
came from the 'old' BSA Factory in Birmingham. When this place closed down a friend of mine bought this.
[img]
[/img]
This picture shows the basic lathe - there are also lot's of bits with it, they include;
1) Single Phase electric motor
2) 3 jaw chuck
3) 4 jaw chuck
4) Assorted gears for the screw cutting arrangement
5) Drill chuck on a Morse taper to suit the tailstock
6) Drive belt
ALL THE OTHER BITS CAN BE SEEN HERE; MORE PICTURES
It is NOT complete and ready to run. You will also need;
1) Some pulleys to fit to the motor shaft to put the drive belt on
2) a Tool post for the cutting tool
3) Some way of mounting the motor
4) a method for applying tension to the drive belt
This is an ideal way for someone with some ingenuity to get themselves a full metal cutting lathe cheaply.
I'm after £225 and you'll need to collect it - I'm in Studley, Warwickshire and work at Gaydon in Warwickshire.
Either U2U or email me at; jus<dot>gardner<at>gmail<dot>com
[Edited on 4/6/12 by JAG]
Justin
