Author: Subject: FS: Radio Controlled Electric Stunt Plane
Barkalarr
Contributor
Posts 945
Registered 14/3/12
Location Essex
Member Is Offline
Photo Archive Go!
Building: Caterham R300, Caterham Roadsport,Indy R1,Indy Zet
posted on 7/10/12 at 08:46 AM Reply With Quote
Multiplex Sky Cat radio controlled electric model plane ready to fly. It has 7.2v battery, 4 channel radio equipment, upgraded brushless motor (AXI 2820/10) and original box / manuals etc - all you will need is a 7.2v battery charger about £15 from ebay, 12x AA battery and a large field.
I've only flown it a few times - it's too quick for me.
This model can be either glow plug or electric. I went electric because it was more convenient. The motor and speed controller alone was £125 back in the day.
SPECS: Wingspan: 42.7 in (1085mm) Wing Area: 480.5 sq in Weight: Min weight for glow, (3.5-4cc), 38.8oz (1100g) Min weight for electric, 52.5 oz (1488g) Wing Loading: 11.5/11.8 oz/sq ft (35.09/36 g/sq dm Length: 40.7 (1034mm) Airfoil: MPX symmetrical mid wing Center of Gravity: 3-15/16"-4-5/16" (100-110mm) aft of the wing root leading edge at the fuselage sides. Control Throws- Ailerons: Up & Down 0.87"(22mm) up, 0.71" (18mm) down Elevator: Up & Down 0.71"(18mm) up, 0.39" (10mm) down Rudder: Right & Left 1.2" (30mm) left, 1.2" (30mm) right
The plane is in one piece, so you will have to come pick it up. I'm 15 mins from Stansted Airport.
£145
Duncan36
posted on 7/10/12 at 05:57 PM Reply With Quote
Try putting it on www.bmfaclassifieds.co.uk it's a dedicated rc site. You may get a lot less for it there though as the model came out about 9 years ago and the market is dead at the minute
Good luck
Duncan
[Edited on 7/10/12 by Duncan36]
