Benzine
| posted on 21/10/12 at 07:55 PM |
FS: Swirl pot and fuel pumps
Swirl pot, good condition. Has a little bit of black paint over spray on the mounting plate (just needs attacking with celly thinners)
Low pressure fuel pump is a Facet EFP-3.
High pressure fuel pump is one I bought from ebay years ago, not sure of the brand. It's had little use. I riveted on some connectors and sealed
them with hot glue gun (was in a quite exposed position so wanted to limit corrosion on the terminals) You can either use the inch or so of wire left
to connect your wiring to or cut back the silicon/glue with a sharp blade and drill the rivet out to have it back to standard terminals.
Swirl pot is the top one on this page:
Link
The lot: £60 inc postage.
Swirl pot £30, Low pressure pump £15, high pressure pump £20.
Russell
| posted on 21/10/12 at 09:23 PM |
U2U sent...
I'm a bilingual illiterate. I can't read in two languages.
Benzine
| posted on 21/10/12 at 09:37 PM |
Sold!
