Author: Subject: Weber 48 Carbs & ECU
keybaud
posted on 27/10/12 at 10:57 AM Reply With Quote
I'm selling a pair of Weber 49 Carb for £445 + P&P
They are complete with throttle position senser, air horns, backing plater, filter, connecting hoses and a pressure regulator. They were used on a C20XE 'redtop' and I can provide this manifold at an extra cost if the buyer needs one.
The engine had been mapped at 230 hp with the carbs and the original seller provided the following details for them:
Main Jets: 165
Emulsion Tubes: F11
Idle Jets: 55F9
I'm also selling the MBE ECU and loom for £325 + P&P
The ECU is a MBE 967IG ECU and is mapped for the Weber 48s on a C20XE. It has the additional Throttle Position Sensor cable, which is additional extra to the standard MBE ignition loom. I will also include a female connector for the dash interface cable, a relay and the serial cable to connect a PC to the ECU.
Both items can be seen before purchase or collected from Malvern.
[Edited on 27/10/12 by keybaud]
