jps
| posted on 12/1/13 at 06:10 PM |
FS: 2.0 litre Ford Zetec Silvertop engine
Title says it all, i've stuck it on eBay too - here: http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=190783265180 but happy to sell to
anyone on here if they will give me £100 for it...?
Basically, it was one of MANY bits I got with a rolling Haynes chassis in the summer. I then bought a donor Sierra with a Pinto engine which I intend
to use. So I have no need for the Silvertop.
No idea of the background to the engine, the bloke I got it from was intending to use it in his build though, so I can only assume he'd picked
one that he thought was decent....
Not knowing anything about it I will likely not be able to answer any questions. I think he said one of the random bits of wiring he gave me was part
of the engine loom - but someone else would have to confirm that!!!
big_wasa
| posted on 12/1/13 at 06:27 PM |
Shame your not local as would have that as a spare / bench engine. It looks like a phase 2 so will be post aug 95 but if it does have a full engine
number and it shows its pre aug 1995 it would increase its value no end and would even be worth a rebuild for some one wanting to get a set of carbs
through iva.
jps
| posted on 12/1/13 at 07:19 PM |
it has number 958u6090_cc stamped on the head (its dohc I guess?) and the longest number i can find stamped on the block, which i assume is the engine
number, is 09j97... Mean anything to anyone?
bob
| posted on 12/1/13 at 07:37 PM |
Engine number
Hi
Engine number can be found on the block flange at the flywheel end exhaust side, its where the crank position sensor reads the flywheel.
big_wasa
| posted on 12/1/13 at 07:38 PM |
engine number is on the edge of the flange that the gearbox bolts to near the crank sensor, exhaust side.
First two letters give you the month and year.
jps
| posted on 12/1/13 at 07:56 PM |
I'll check it out tomorrow. Cheers chaps
jps
| posted on 13/1/13 at 11:42 AM |
Had a look, rubbed some crap off the block and the first letters are NG as far as i can tell. According to Burton power site that makes it a1992
engine, is that possible?
AdrianH
| posted on 13/1/13 at 12:06 PM |
That probably just means it is a NGA or NGB engine. What are the next few letters.
For example I have an engine with the number RKF XE 742 etc.
RKF is 1.8 and XE is April 1999.
Adrian
Why do I have to make the tools to finish the job? More time then money.
jps
| posted on 13/1/13 at 12:41 PM |
Ah, yes, becomes illegible as you read on but looks like nga vk which would make it '98 i think...
jps
| posted on 13/1/13 at 04:21 PM |
