Throttle bodies and ECU
Here is a throttle bodies and ECU set up ,I got a lot of bits together for a couple of projects but I’m never going to use these so I might as well
try and sell them as they will only sit and gather dust!
1 x pair of throttle bodies from an E30 M3 these are 45mm with individual air bleed screws, and a combined air bleed for idle speed, they taper down
to fit a 16 valve head, 100mm spacing’s same as Jenvey TB’s unfortunately the fuel rail is missing, A Jenvey rail will fit. Comes with Saab 9000
injectors (380cc) these bodies are in great condition and working perfectly. An adaptor plate or manifold will be required to fit this set up onto
anything other than a BMW, originally they had rubber mounting blocks to attach them to the head, I can supply them if required, this will make a
great set up for any 2ltr engine
Gotech MFI pro V6 ECU these are great little ecu’s for all the info see the website
http://www.gotech.co.za/productpro.html
The software for programming it can also be downloaded from that site, comes complete with instruction manual, serial cable, spare connectors,
instruction book and wiring loom which will fit most 4 x cyl motors
I would prefer to sell this as a lot and would like £400 for it all as in the photo. If you want to view before purchase please let me know
If interested please contact via u2u messenger
