Author: Subject: FS gearbox's, steering columns, diffs, driveshafts etc
gavin174
posted on 29/4/13 at 08:11 PM Reply With Quote
Right I am having a workshop clearout....
more bits to be added.
I am going to Stoneleigh Saturday and staying till monday. I can take any of these bits with me.
type 9 gear box with bellhousing rear mounting point has been modified, no gear stick.. £125
type 9 gearbox with bellousing rear mounting point has been removed and a new one welded on, no gear stick.. £125
adjustable steering column.. barrel and key, but not switches.....£50
adjustable steering column.. barrel and key but no switches.. £50
steering column cowl.. good condition, needs washer on top screw.. £20
pinto exhaust, stainless steel through the side panel, with heatshield..£100
ally fuel tank, built in sump, 10mm inlet and return in sump, 10mm breather in top approx dimensions.. 700x200x200.. £100
[Edited on 29/4/13 by gavin174]
gavin174
posted on 29/4/13 at 08:33 PM Reply With Quote
sierra 3.62 7 inch bolt on shaft open diff... £65
sierra 3.62 7 inch push in shaft open diff... £65
sierra 3.92 7 inch push in shaft open diff... £65
complete bolt in driveshafts, bearing carriers and hubs... £125
push in driveshaft bearing carriers and hubs... £20- sold
drum brake back plate, shoes fitting kit, cylinders and drums.. £30 - sold
bolt on driveshafts... £40
caterham stainless steel rear exit exhaust, brand new never fitted, these are over £400 new.. £150
[Edited on 30/4/13 by gavin174]
tilly819
posted on 29/4/13 at 09:12 PM Reply With Quote
I will have the push in hubs and bearing blocks off you.
I can collect on Monday from the show.
Tilly
F20C Haynes roadster 440 BHP/Tonne www.youtube.com/handmadeextreme
gavin174
posted on 30/4/13 at 02:57 PM Reply With Quote
sierra handbrake lever... modded to incorporate a combination lock.. £15
standard type 9 gearlever... £15
sierra light and wiper stalk... £15
another sierra light and wiper stalk... £15
sierra ignition barrel and key.. £5
sierra brake reservoir excellant condition... £10
sierra rear caliper shortened springs... £15 - sold
another set of sierra rear caliper shortened springs..£15
sierra handbrake lever....£10
sierra handbrake lever.. £15
[Edited on 1/5/13 by gavin174]
neilp1
posted on 30/4/13 at 04:08 PM Reply With Quote
I'll have one set of sierra rear caliper shortened springs..£15.
u2u sent.
Neil
Benzo
posted on 30/4/13 at 05:27 PM Reply With Quote
What do the shortened springs do? allow for better wheel clearance?
gavin174
posted on 30/4/13 at 10:39 PM Reply With Quote
yes.. they allow a wider range of 13" rims to be fitted....
gavin174
posted on 1/5/13 at 08:56 PM Reply With Quote
I have dropped the price on a few bits...
type 9 gear box with bellhousing rear mounting point has been modified, no gear stick.. £100
type 9 gearbox with bellousing rear mounting point has been removed and a new one welded on, no gear stick.. £100
adjustable steering column.. barrel and key, but not switches.....£40
adjustable steering column.. barrel and key but no switches.. £40
pinto exhaust, stainless steel through the side panel, with heatshield..£80
ally fuel tank, built in sump, 10mm inlet and return in sump, 10mm breather in top approx dimensions.. 700x200x200.. £80
gavin174
posted on 1/5/13 at 08:58 PM Reply With Quote
sierra 3.62 7 inch bolt on shaft open diff... £60
sierra 3.62 7 inch push in shaft open diff... £60
sierra 3.92 7 inch push in shaft open diff... £60
complete bolt in driveshafts, bearing carriers and hubs... £110
