digidash 1 NOW SOLD
See photos, original digidash 1 for sale.
Everything works, shift lights etc.... 8300 miles on clock.
There are NO sensors with it still on my car all available from etb for not a lot, think oil pressure one is the most expensive one.
Been the digidash 1 there is no online calculator for speed calibration, now if you have a busa engine, 3.09 diff and run 13 inch wheels its set up
ready to go if not then its pretty easy to fiddle it, when I changed from blade engine to busa I put sat nav in car to get accurate GPS speed and
adjusted the "pulse per mile" which you can do, took me four or five attempts to narrow it down to give an accurate speed readout after
engine swap.
All plugs are on back with approx 6 inch of cable, I cut them to connect to new dash. I have wiring diagram to connect sensors, its easy enough for a
locostbuilder to do.
Got to be worth £80 delivered ?
[Edited on 10/5/13 by Jon Ison]
