trextr7monkey
| posted on 27/5/13 at 06:05 PM |
Mk 2 escort and x flow clear out ( mostly!)
Having finally waved good bye to the Ninja jeep I can now sort out the garage to make space for Tr7 stuff, rather than faff around with evil bay I
have decided totry and shift it as one pile, I have pics of everything but it would take too long to load each one up, I have a list of what I
candefinitely find and more may emerge for the lucky buyer .
Everything is of Mk 2 escort origins and for x flow engine unless otherwise stated, all spares were kept to use again and any trash was discarded
but i can't vouch for every single bit as some of it arrived a spart of job lots or stuffed inthe back of a car.
X flow clear out
Fly wheel with starter ring , could do with a skim
Fly wheel starter ring and clutch cover fine
Used clutch plate and thrust bearing
Bracket for OS for X flow engine -off world cup x member
X flow starter motors 3 hole x 3
X flow starter motors 2 hole x 1
Mk 2 escort hand brake lever
X flow alternator with plug
X flow alternator without plug
2 thermostat housings with hole in top for sender
Crank pulley
Fan pulley
Clutch operating arm
Clutch arm dust cover for escort box
2 odd strut top caps
1 new old stock top mount some surface rust
X flow flame trap
Pinto breather
Remnants of sierra pedal box – no clutch pedal but everything else is there
2 x X flow fuel pumps and spacers
3 oil pumps
Set of push rods set of head bolts
Set of escort dust shield s- one has been welded + spare and fixing bolts ( 6 bolts )
Pair of escort hubs and discs and studs in good useable condition
Timing chain and crank seal cover s x flow
Pair of NOS escort rea r shocks
Choke cables
Throttle cable s
Clutch cables speedo cables
Steering column switches a nd con wl ful set
Odd steering column switches
Throttle linkages
Gear lever escort
maxi ball joint
Miscellaneous rod end
Couple of exhaust silencers
1300 x flow cylinder head came out of locost 1300 race car , slight crack professionally welded
Engine mounts about 9 or 10
New gasket set
3 ford dizzys Fomoco , Ford Lucas and Ford ( German)
New pair of Mk 2 escort track rod ends
Pair of new steering gaiters
New oil filter
1 spare 1600 fan belt
Box of engine mounts – 9 or 10
£350 takes it all
collected from near Carlisle
Will add a few pics late rshowing some of the stash
atb
Mike
trextr7monkey
| posted on 3/6/13 at 05:24 PM |
starter motors ,
clutch plate cover
thrust bearing and cable
gasket set gone
new rear shocks
Gone, taking offers on other bits
atb
Mike
trextr7monkey
| posted on 4/6/13 at 08:04 AM |
Still got 2 x 3 hole inertia starters and
1 x 2 hole here
