Author: Subject: 4 AGE engines and bits
Camber Dave
posted on 11/11/13 at 08:55 PM Reply With Quote
I am having a clear out of my garage after changing the donor for my project.
Before I eBay the following items I thought that I would offer them here first. I can deliver locally FOC.
• A very good 1600 4A-GE that I removed from an MR 2 when I installed a 20 valve engine about 6 years ago. This engine kept stalling when cold but ran well when up to temperature. I found that water had been leaking into the ECU from a leak in the car boot seal. This may have be the cause of the stalling.
• A T50 Gearbox with bellhousing from an AE86 RWD Corolla. The synchro on third gear is weak but otherwise the box is quiet. As you probably know this box has a cracking set of ratios unlike the Ford Mk9 normally used.
I have searched ebay for 12 months to establish its value and only one was listed and sold at £350
• A 4A-GE that came with twin 40 Dellorto’s. With it is a Ford Base plate, spindle and advance bob weights. This means that it can run on contacts and a coil or Electronic ignition. An ECU not therefore required this would be ideal for a basic Locost kitcar.
• A bellhousing that fits 4A-GE engine to T50 box. With it is a 25 mm Steel adapter to fit to a Mk 9 Ford box. It came fitted to the engine above.
• A 4A-GE taken from a AE86 Corolla. This engine has been stored for about 10 years and has is rings stuck but ran well before being removed (ie now requires a bore hone and rings / bearings as a light refresh).
• A New 4A-GE to DCOE inlet manifold from Raw Engineering. With it are 2 Dellorto’s stripped and sleeved as throttle bodies. It will also take Webbers or Jenvey throttle bodies.
• Various manifolds, a good Toyota ECU, an AE89 engine harness and T50 front prop (box to centre bearing).
• 2 MR2 Mk One gearboxes. One was bought as a space model to design and build a chassis around. The seller threw in a second box with good internals to make a good one from the parts.
Ring 07977 948883 or U to U me with your interest and questions and we can negotiate a price for the bits you want.
Some bits will be very cheap! Price for the job lot £600! Delivery Free 50 miles from J17 M4
All offered here as lumpy bits are a pain to sell on eBay.
Camber Dave
posted on 20/11/13 at 03:42 PM Reply With Quote
MR 2 Boxes Sold subject to collection
I have had a few calls on these bits
Just to confirm that all parts are available separately or pick and mix!
