For Sale - hydraulic pump cylinder kit (RS p/n 605-223)
Surplus to requirements and used once, possibly twice at work.
Looks to retail for £600+ in RS, details taken from RS website...
Hydraulic Pump & Cylinder
Producing 5000 psi pressure over a 19mm stroke, the pump removes much of the effort required when cutting by hand and has the necessary force to make
much larger holes in panels up to 3mm (10 swg) thick steel (hand hole cutters will still be limited to 1.6mm maximum cutting thickness in steel and
2mm in aluminium)
With 1.8m of flexible connecting hose for use with the majority of hole cutters in this section
Spring return operating lever has handgrip that may also be pumped by foot
Can be used to power hand hole punches, using adaptors supplied
Outlet port size 1/4in. BSP
Cylinder hole 25mm diameter
Supplied in 570mm long x 230mm wide x 150mm high storage/carrying box, total weight 14.5kg
Pump has special draw bolt, washer and colour-coded adaptors to suit various hole cutter thread sizes
Box incorporates partitioned area for storing smaller hole cutters
£150 with free UK next day shipping included.
