lots of parts
9" 275lb 1.9"id springs pair black £25 delivered
7" 300lb 1.9 id springs pair black £25 delivered
zetec rwd flywheel re-drilled for pinto clutch £65 delivered
crossflow side exit distributor, fast road spec, points £45 delivered
zetec rwd conversion water pump for 2.0 silvertop zetec with the correct ribbed pulley £30 delivered
zetec smoothed and powdercoated satin black rocker cover for silvertop £25 delivered
jenvey inlet trumpets for 40mm bodies, 40mm tall. set of four, £40 delivered
thanks for looking, if you want any pics send me an email to arrow-engineering@hotmail.co.uk and ill sort you out.
andy - 07891 604755
