Author: Subject: 2x fuel tanks, 13x7 Superlites, Westfield boot box
msisleman
posted on 23/11/13 at 10:24 PM Reply With Quote
A few things for sale. Firstly, a brand new never used, 6 gallon aluminium fuel tank. I tried to fit it in the space I have on my car, so there are a few marks where it's scraped against wishbones etc, but it has never seen any more action than that. Has a 10mm fuel out, 10mm return, 50mm filler and 50mm sender hole. Comes with laser cut tank straps. The dimensions are: 615mm width, 250mm depth, 180mm height at the bottom, 160mm height at the top (its a slightly sloped shape). £100 posted.
https://db.tt/RZb47x8F
https://db.tt/M8wiGvUO
Another fuel tank, a (just under) 2 gallon tank for sprint, hillclimb and autotest use. This has seen some extremely light use, no more than 5 tanks of fuel put through it. Made by Ali Fab, lovely piece of kit. Dimensions: 300mm x 200mm x 150mm. £70 posted.
https://db.tt/1LCoaV5h
Westfield SEIW boot box in red. Great condition, don't think there's a mark on it to be honest, never been fitted to a car! £70 posted.
https://db.tt/dB8rHXW2
https://db.tt/sQi2PKeW
A set of Superlite alloys, these are basically brand new, been fitted to my car, found they don't quite fit over my calipers, and not used. A few marks on the inside where they've slightly fouled my calipers etc. They are 13x7, 108pcd, ET-7. They have super soft Yokohama sprint/hillclimb tyres fitted, front 160 515 13, rears 180 515 13. The fronts are basically new, and the rears are about half worn with plenty of life left. £450 collected.
I am willing to split tyres from rims if the demand is there.
https://db.tt/QfLNCvrB
https://db.tt/N6uEmtsk
https://db.tt/JXxEDi4d
https://db.tt/QwpWvCIr
https://db.tt/s3VYdXRD
https://db.tt/iy5xkcyV
Any questions or anything, get in touch!
Thanks,
Craig.
[Edited on 23/11/13 by msisleman]
scimjim
posted on 23/11/13 at 10:29 PM Reply With Quote
Linky no worky?
msisleman
posted on 23/11/13 at 10:47 PM Reply With Quote
Sorry, one sec....
msisleman
posted on 23/11/13 at 10:56 PM Reply With Quote
Should be working now!
Barkalarr
Contributor
Posts 945
Registered 14/3/12
Location Essex
Member Is Offline
Photo Archive Go!
Building: Caterham R300, Caterham Roadsport,Indy R1,Indy Zet
posted on 24/11/13 at 08:33 AM Reply With Quote
U2U sent re: big tank
daniel mason
posted on 24/11/13 at 08:47 AM Reply With Quote
are there +7 or-7 offsets? i could do with some 7"rims for the front of my radical!
msisleman
posted on 24/11/13 at 11:08 AM Reply With Quote
They are -7 offset, so fairly dished.
msisleman
posted on 24/11/13 at 11:12 AM Reply With Quote
A few omissions. The tanks are both baffled but not foam filled. The small one has 10mm fuel out, 10mm return and a threaded filler hole with alloy filler cap. I am based in Braintree, Essex, but travel a bit so might be able to deliver to some places, please enquire.
[Edited on 24/11/13 by msisleman]
msisleman
posted on 26/11/13 at 08:58 AM Reply With Quote
Everything now sold, apart the Westfield SEIW boot box, thisis still available.
Craig.
