jwhatley
| posted on 20/12/13 at 08:06 PM |
Mocal Oilstat Sandwich plate, W/Mocal 16 row Oil cooler
I have this kit in another box of goodies, this has been sat redundant for a while and I'm never going to use it.
It is a Mocal oilstat sandwich plate housing - OTSP1M18X http://www.thinkauto.com/acatalog/On_line_shop_Oilstats_30.html
I believe this was fitted to a VW engine but fits any other engine by changing the sliding adapter within the centre of the plate (extension bolt)
which can be found here: http://www.thinkauto.com/acatalog/Extension_Bolts.html
The housing accepts 50-74mm oil filters, and is an SP1 type A fitment as per: http://www.thinkauto.com/takeoff.htm
currently has -8JIC fittings included.
Comes with a -8JIC fitted 16 row 235mm oil cooler - OC516 series http://www.thinkauto.com/acatalog/On_line_shop_230mm_width_3.html
No damage to it other than to what can be seen in the photos.
Also comes with 1x 2ft hose and 1x3ft hose with -8JIC fittings attached and a -8JIC adaptor to fit in an oil temperature sensor take off.
Brackets will be removed as there no use to man nor beast!
All these parts come to more than £150 if you include the fitting prices.
Looking for £100 plus postage
John
[Edited on 20/12/13 by jwhatley]
jwhatley
| posted on 27/12/13 at 02:44 PM |
SOLD
