Daddylonglegs
| posted on 12/1/14 at 09:48 AM |
Major clearout
We are moving house in the next couiple of months so it's clear out time!
Zetec Blacktop 2L:
I fully intended to fit this to my Locost but it is just one of those 'maybe next year' projects so she's going.
No.3 piston is not connected to the crankshaft so either conrod or little end has gone (water damage write-off car - that's all I know about
it). The rest moves fine, no binding or odd noises (apart from the No. conrod catching every revolution). The engine is aas seen in the pictures, I
also have another good bottom end which I was going to use to rebuild the other one. Comes complete with flywheel/clutch but will need new friction
plate and surface of clutch unit cleaning off but it is sound. There is also the manifold as shown.
I only want to cover my costs so £60 collected.
Triumph spitfire fuel tank, couple of minor patches but no leaks last time I tried it. Holds about 8 gallons I believe.
£20 collected
Pinto manifold off 2L I think but not 100% sure. £15 collected or plus postage
Pinto manifold, not sure whether 1.6 or 2.0. £10 collected or plus postage
Zetec coil pack and leads. £40 collected or plus postage
EDIS 4 ignition unit. £30 collected or plus postage
Exhaust can, £15 collected or plus postage (measurements to follow)
Selection of Pinto bits: Sump, oil pickup and strainer, Rocker cover, timing belt cover, Carb, set of vavle springs (I think they were from a 1.6).
FREE to collect!
Almost forgot:
Sierra steering wheel, IVA safe £20 collected or plus postage.
I'm sure there will be more so I will post as and when.
PM me for any more info.
JB
[Edited on 12/1/14 by Daddylonglegs]
Daddylonglegs
| posted on 13/1/14 at 09:56 AM |
Bump ^^^
silverback
| posted on 14/1/14 at 03:13 PM |
U2U sent.
