Daddylonglegs
| posted on 3/2/14 at 04:01 PM |
Zetec 2l 16v Blacktop - spares or repair
I have a 2l Zetec Blacktop which needs a replacement piston or conrod as number 3 isn't moving with the crank. I also have a Zetec bottom end
which I was going to use for spares to try and get the blacktop working. Not sure of the specifics of either, but just need them gone now before we
move.
Also have a clutch/flywheel which will need TLC and new friction plate, and both manifolds are there too. Engine turns fine but you can here a light
'clink' every revolution when the engine is turned by hand. The bottom end I bought spare also turns over fine and the bores look good
with no lips.
If anyone wants to come and take it away for the princely sum of £20 they are welcome.
PM me for anymore info.
I also have a Zetec coil pack and leads for sale - £30 posted)
pekwah1
| posted on 3/2/14 at 04:55 PM |
Is the flywheel/clutch etc the standard 2.0 gubbins?
Daddylonglegs
| posted on 3/2/14 at 05:06 PM |
Not sure chap, but I assume so. Got the whole thing as a job lot.
19sac65
| posted on 5/2/14 at 06:36 PM |
Ille take them for £20
When are you moving as itll be a week or so before ime down that way with work
Daddylonglegs
| posted on 6/2/14 at 04:51 PM |
u2u sent
