kingster996
| posted on 13/11/14 at 04:52 PM |
Fuel Tank for sale
I have a fuel tank that I bought a while back for my Westy - but the fuel outlet pipe is right in front of the diff mount on my SEiW chassis, and it
turned out to be a carb tank with no return pipe when I wanted one to suit injection - ho hum.
It should easily fit most other 7 style chassis designs that don't use the rear brace that Westfield use - or a live axle Westy of course. It
will suit a carb setup or will need a minor mod (return adding) and a swirl pot for injection use.
Includes a VDO sender unit and a brand spanking new breather valve bought from CBS
(linky) and fitted but never used.
Never fitted it as I ended up just buying an injection tank instead of modifying it to suit my needs.
It stands me at £90 inc the £30 breather valve so would just like to get my money back.
I used to be indecisive, but now I'm not so sure
Benzo
| posted on 13/11/14 at 05:05 PM |
Edit - Never worry, wont do my job.
[Edited on 13/11/14 by Benzo]
kingster996
| posted on 13/11/14 at 05:17 PM |
Capacity is around 30 litres
Here's a pic of a similar tank showing approx dimensions - if you need perfect dimensions let me know and I'll go measure.
Benzo
| posted on 13/11/14 at 05:39 PM |
Are these Baffled?
CosKev3
| posted on 13/11/14 at 05:42 PM |
quote: Originally posted by Benzo
Are these Baffled?
I would guess so looking at the spot welds showing on front and rear of tank?
kingster996
| posted on 13/11/14 at 05:50 PM |
As Kev says - yup, two baffles where the spots are
kingster996
| posted on 13/11/14 at 07:32 PM |
Now sold.
