Norfolkluegojnr
| posted on 10/1/15 at 09:49 PM |
Twin 40s, harnesses, brakes, rad loads of other stuff...
Twin Dellorto 40s on crossflow manifold - includes a throttle linkage that worked well on my car. Bit grubby, but in fine working order. - £175
posted
2 x 3 point OMP harnesses with seatbelt buckle - we're fitted in my striker. Top fixing is a loop round for roll bar, bottom is bolt in - £50
posted
1 x 3 point Sparco harness with seatbelt buckle - all bolt in points, long top strap as came out of my mini turbo. £25 posted
2 x Willans crutch straps - not used when I fitted the harnesses to my striker. We're originally from a radical. £offers
1 x escort radiator - decent condition, no bent fins, cools well. £20 posted
1 x set of 1.8 MX5 brakes - 2 front calipers, 2 rear. No carriers. All work but I'd reccomend a rebuild. £30 posted (pics on request)
1 x Lumenition module - took this of the car so no idea if working or not, it's only the module, not the bit that goes in the dizzy. £20 posted
and if it doesn't work, you can send it back and I'll refund you!
1 x boost gauge - works fine, pair a bit worn. £10 posted
2 x 10" wiper blades bayonet type. New. £10 posted
1 x ford tps sensor £5 posted
1 x ford viscous fan £5 posted
Rover 45 Haynes manual new £5 posted
Sony Xplod sub woofer 300w - one of the stranger things I've removed from the kit! £15 posted (it's quite heavy)
1 x zetec pressure plate - free or pay the postage
Open to offers on anything, I'm near Norwich if you wanted to collect any items, free tea with any purchase!
harris
| posted on 11/1/15 at 03:16 PM |
Carbs
Hi I'll take the carbs. I've u2u you as well
Cheers Matt
[Edited on 11/1/15 by harris]
Norfolkluegojnr
| posted on 11/1/15 at 05:09 PM |
U2U replied
Norfolkluegojnr
| posted on 11/1/15 at 08:50 PM |
Worth mentioning I'm happy to swap with cash either way foe ignition only Ecu or wideband lambda.
Norfolkluegojnr
| posted on 13/1/15 at 09:23 AM |
Quick bump before it all goes on ebay.
