Andybarbet
| posted on 20/6/15 at 11:10 AM |
For sale - Wilwood remote brake reservoirs x 2
I have 2 brand new Wilwood reservoirs with mounts & caps £35 posted.
  Brake reservoirs
  wilwood reservoirs
These are £35.50 each on Rally design website.
http://www.rallydesign.co.uk/product_info.php?products_id=16867
I don't have any brake pipe or aluminium fittings for the master cylinders though.
Cheers - Andy
[Edited on 20/6/15 by Andybarbet]
Greenie
| posted on 20/6/15 at 12:42 PM |
Can I have first dibs on these, but please can I have the dimensions, more bothered about the height from top of cap to the base.
Thanks Peter
Andybarbet
| posted on 20/6/15 at 12:57 PM |
Yep, just measured one,
The bracket section is 55mm high, top of filler cap to top of bracket is 95mm so overall height is 150mm if that helps ?
Greenie
| posted on 20/6/15 at 02:46 PM |
Cheers, may have to separate them, what is the width, looking a little tight, but may be able to put an elbow into one of them?
Peter
Andybarbet
| posted on 20/6/15 at 03:16 PM |
The cap is 55mm diameter, the body & mounting part are 52mm wide.
Outlet on bottom looks to be about 10mm but I can measure exactly if it helps
Greenie
| posted on 20/6/15 at 03:17 PM |
Please it will help......
Greenie
| posted on 20/6/15 at 03:24 PM |
U2U Sent
Andybarbet
| posted on 20/6/15 at 03:59 PM |
Output on bottom is 10mm, just heading out but will reply to u2u a tad later - cheers
Andybarbet
| posted on 21/6/15 at 10:20 AM |
SOLD :-)
[Edited on 21/6/15 by Andybarbet]
