mackei23b
| posted on 6/12/15 at 01:54 PM |
For Sale: DRE Sequential Shift Lights
For Sale
DRE Shift Lights £50 inc delivery (Picture is the actual item)
Features:
· 5 super bright lamps
· Built in digital display for easy set-up and data retrieval
· Individual or pair illumination for warning lamps
· All settings are programmable without starting the engine
· Shift flash facility
· User programmable 'shift light' set point (from 3000 rpm to 20,000 rpm)
· User programmable 'lowest light' set point
· Intermediate set points calculated automatically
· Maximum rpm recall facility
· Shift lamp brightness control for night time use - 6 brightness levels
· Compatible with 1, 2, 3, 4, 5, 6, 8, 10 or 12 cylinder engines
· Stall warning facility - all five lamps flash (slower than shift flash) if the engine stalls
· Anti-flicker system - prevents lamps from flickering when approaching the shift point
· Can show the actual rpm on the display for setup purposes
· Non-volatile memory - all data is retained even if the power is disconnected
· Ultra-compact size - mount almost anywhere
· Extremely lightweight
· Extremely easy to install (simple 3 wire connection)
· Reverse polarity protected
Ian
[Edited on 6/12/15 by mackei23b]
mackei23b
| posted on 7/12/15 at 09:12 PM |
NOW SOLD
Here are a couple of extra pics with the actual unit powered up that is for sale:
Below are the Shift LEDs on (They are very bright when viewed straight on):
Below is the LED display that you use to set the max/min RPM etc:
Very easy to set up.
Ian
[Edited on 7/12/15 by mackei23b]Text
[Edited on 9/12/15 by mackei23b]
