Zetec coil pack, flywheel, silencer, springs, gauges, etc... Stufffff...
Hello all, having a bit of a garage clear out - all located in Aberdeen up in Bonnie Scotland. I drive down to Knockhill quite regularly so if anybody
wanted to meet me there that would be fine.
Quaife straight cut, synchro gearset and ford motorsport viscous limited slip diff, to suit FWD BC gearbox - will need to be built up into a gearbox -
I can do this for an additional cost - £1,500.
SBD air filter with aluminium back plate to suit SBD Duratec throttle bodies - never fitted as it won't fit on my car - cost £154 new - £100
delivered.
Exhaust silencer, stainless, 6" body, 2-1/4" pipe, 14" long, comes with the two clamps - I cut the body down to size as it was
slightly longer - Probably £20 but would need to get an idea on postage.
2-1/4" coil springs, 450lb/in, 7" long - £15 posted
Silvertop Zetec coil pack, can send the HT leads for spares if required - £15 each posted
Fiesta ST 150 Duratec sump - Probably £25 posted but will need to get a better idea on postage
Wilwood Pull Type Slave Cylinder for converting clutch to hydraulic - £50 posted
Fiesta ST150 Duratec flywheel - Probably £40 posted but will need to get a better idea on postage
Malpassi Petrol King Regulator For Carburettors - £40 posted
Dan ST Duratec stainless steel exhaust flange with 1-7/8" port holes - never used - £35 delivered
https://danstengineering.co.uk/index.php?route=product/product&product_id=188&search=duratec
Sierra drive hubs / Rear Axle Outer Stub - think this is 100mm / 86mm PCD - £20 posted
Westfield rev counter, 80mm - does not have the light holder in the rear for illuminating - £30
VDO temperature gauge, 52mm - does not have the light holder in the rear for illuminating - £20
Durite oil pressure gauge, 52mm - does not have the light holder in the rear for illuminating - £20
Ford Fiesta ST150, Duratec, gearbox - £200
Spare wheel carrier for Brian James Minno trailer - £30 delivered
1 x rear support stand for Brian James Minno trailer - £15 delivered
All items located in Aberdeen in Scotland.
[Edited on 4/11/17 by cosmicicecreamman]
[Edited on 5/11/17 by cosmicicecreamman]
