andyw7de
| posted on 18/8/08 at 05:04 PM |
gear and handbrake suround
very special offer
As above cut from 3mm ali
£3 each inc del
see pic.jpg)
saigonij
| posted on 18/8/08 at 05:12 PM |
excellent!
Ill have 1 of the hand brake gaitors, and 2 of the gear lever gaitors.
ill email you later on.
Ian.
StevieB
| posted on 18/8/08 at 05:21 PM |
Looks good - can you give me the overall dimensions?
Outer and inner dims would be good (I've already cut an aperture for the handbrake and want to know if the surround would cover the hole.
cjtheman
| posted on 18/8/08 at 05:41 PM |
same here mate dims please mate
cheers
colin
novacaine
| posted on 18/8/08 at 06:51 PM |
put me down for both,
do you accept paypal?
Matt
And you run and you run to catch up with the sun but its sinking, Racing around to come up behind you again, the sun is the same in a relative way but
your older, shorter of breath and one day closer to death
DavidW
| posted on 18/8/08 at 07:22 PM |
Subject to dims, yes please to both.
andyw7de
| posted on 18/8/08 at 07:23 PM |
Sorry about the dims guys
Gear suround is 140mm x 120mm outside the band is 20mm wide
Handbrake suround is overall 250mm long 80mm wide with a 20mm wide band
However these can be cut to suit your individual requirements.
Just let me know what you need
cheers
PM me if interested
DavidW
| posted on 18/8/08 at 07:29 PM |
Handbrake is spot on, any chance of a round gear surround? It may be easier to make a leather thing to fit.
andyw7de
| posted on 18/8/08 at 07:44 PM |
Yes David round is easy what diameter would be best suited
cheers
DavidW
| posted on 18/8/08 at 07:47 PM |
Thanks Andy
Unless anyone has good suggestion, I'll check when I get home on Wed.
