mikeb
| posted on 8/9/08 at 09:48 AM |
Helicoil kits and taps FS
1xrecoil kit in plastic case new m8 x1.25
Has tap 8 coils insertion and tang tool.
1xrecoil kit unc 3/8-16 same as above
helicoil M6 kit short, medium and long coils (6 each) m6 helicoil tap , tool and rod, missing the 1/4 hss drill though might be around somewhere.
Kennedy Pro Wire thread repair kit 3/8 unc. This is a nice little kit with tap, drill, tang tool and 7 coils
Helicoil m10x1.5 tap
Helicoil m6x1.6 tap straight flute roughing tap
Helicoil m10x1.5 straight flute roughing tap
5/16 unf second tap
3/8 UNC bot tap
set of 3 3/8 unc tap rough, second and bottoming
Make me an offer for the lot!
[Edited on 8/9/08 by mikeb]
lsdweb
| posted on 8/9/08 at 12:39 PM |
Mike
I'd be interested in the 6mm and 8mm helicoil kits if you'd split the set.
Regards
Wyn
