| posted on 29/10/08 at 10:27 PM |
Clear out - Pinto parts and other bits and pieces
Having a bit of a clear out in the garage and have the following bits and bobs...
Pinto ignition module - £10 posted - SOLD
Sparco pedal cover - £3 posted
Fuse block 4 way - £2 posted
25mm plastic end caps - £1 posted - SOLD
Rocker switch with orange LED - £2 posted
Fog warning lamp - £1 posted
Pinto engine seals, crank, fuel pump, water pump, 7x valve stem (no idea what happened to the 8th) and camshaft - £3 posted
Pinto temp sender - £2 posted - SOLD
[Edited on 29/10/08 by nick205]
[Edited on 30/10/08 by nick205]
MK chippy
| posted on 29/10/08 at 11:15 PM |
Plastic end caps
Hi nick,
if you still have them can i grab the end caps if they are the size of the steel square section on the mk chassis? For some reason there is a hole in
both of the rear arch areas.
Dave
I will collect
gavin174
| posted on 30/10/08 at 03:06 AM |
id like the amp and temp sender please
| posted on 30/10/08 at 09:15 AM |
Yours if you want them - U2U sent with email address for PayPal.
Nick
| posted on 30/10/08 at 09:18 AM |
quote: Originally posted by MK chippy
Hi nick,
Dave
I will collect
U2U sent
