Been busy making an exhaust manifold, my plan is to use spring & eye retainers on the 4 pipes into the collector. Am I better off hard mounting
the collector to the chassis, or arranging it on a rubber bobbin type thing ?
Do I need to soft mount all of the system on bobbins for the vibration etc ? exhaust virgin....
Can you hang the collector off the engine?
So manifold and collector move as one, is your engine hard mounted or on av mounts?
Personally I would rubber mount everything to reduce vibration and reduce stress.
Rubber mount engine and exhaust if possible for best results imho. Cheers
Me too! Or fit a small flexy in the system.
