Wanted Rover 1.6 K series head.
Danozeman - 24/1/09 at 12:26 PM
I desperatley need a K series head for a 1.6 rover if anyone has one spare somewhere. Must be useable with valves. I dont mind having it skimmed to face it off.
Money waiting.
Thankyou.
britishtrident - 24/1/09 at 01:38 PM
All l k16 series heads are the same --- from the 1.4 to the 1.8 turbo.
Except at the end of 1999 the cam belt tensioner was redesigned --- not a major problem can be got round.
This was introduced as part of a package of mods including the introduction of a cam phase sensor, wider cam belt and coil pack ignition.
Danozeman - 24/1/09 at 02:59 PM
Mine has this. Do the newer belt adjusters fix to the head in the same way?
Mines a 2000 x reg
britishtrident - 24/1/09 at 03:21 PM
I am 95% sure that a bit of work with a drill and tap can convert one to the other ---- one thing to watch is the cam phase sensor if swapping complete unit as I don't think all older style heads have the half circle bit on the camshaft to trigger it.
