Need about 350mm of 60mm ID tube with a 1mm wall thickness. Anyone got an off cut or point me in a direction to get hold of some??
Ta!
youll be lucky to find it with that ID .
most tubes are 63mm /60mm OD , you then specify what gauge you want - which sounds 18/20 gauge to me .
ooops!!!
60mm OD is whats required!!
B and Q
They sell table legs, which are steel tubes about 60mm OD.
With 1mm wall thickness? The ID is quite important too.......
well , it sound slike you need some 20g 60mm tube then !
whys the ID so important ?
most of the tube i can lay me hands on is 16g.
Modifying an exhaust with a cat in it for SVA. Have to match it onto an existing header. I have no idea of the guage as metal aint my thang. I do know
that 60mm OD with a 1mm wall thickness is whats required!
have you tried talking to a stainless exhaust manufacturer there must be one near you
like
Stealth SystemUnit 3 manor ind est, manor house ave , millbrook, s,
Exhaust manufacturer ,mandrel tube bending ,custom exhausts for bikes ,cars ,trucks ,boats etc
Stainless steel specialists,stainless steel tube suppliers ,exhaust compontent supplier.
just one from a quick search I've always found these small kinds of companies really helpful
Pete
I know of Stealth but I wont have time to get over there unfortunatly. Was hoping to find something on the web.......
I have some 63mm OD (approx 1mm wall) stainless and could cut 400mm of it if you want.
Won't cost you anything - unless you want to put a little in an RNLI or similar collection.
It's only a couple of mm oversize, and I'm sure you could cut and bend the end in a bit before welding
Simon
Hi Simon,
Your on! Thanks for the generosity.
