I've been persuaded that a BEC would be enormous fun, and so I'm after one! I'm open to all the different makes, as long as it's
in good mechanical/electical order. Doesn't have to have a reverse box, I don't mind pushing it around! I'd like to track it at some
point, so would like some kind of appropriate oil management, e.g. sump baffle. Preferably it'd be <£7000 and ideally it'd be
<£6000.
If you spot one could you give me a shout please
(I've already been scanning PH so don't worry about that!)
Cheers all
dont be a wimp build one. this is locost BUILDERS afterall so expect more comments of that nature.
have you looked in the forsale section?
U2U response sent (finally!), Matt.
Originally posted by Mellow Matt
I've been persuaded that a BEC would be enormous fun, and so I'm after one! I'm open to all the different makes, as long as it's in good mechanical/electical order. Doesn't have to have a reverse box, I don't mind pushing it around! I'd like to track it at some point, so would like some kind of appropriate oil management, e.g. sump baffle. Preferably it'd be <£7000 and ideally it'd be <£6000.
If you spot one could you give me a shout please(I've already been scanning PH so don't worry about that!)
Cheers all
I've got a GSXR that needs a gearbox rebuild, so I'll learn a bit more there, hopefully build up a decent amount of skills!you have email
