Can someone machine a part for me!!!
prawnabie - 12/4/09 at 01:38 PM
Hi
Basically I have bought a steering wheel with no fixing holes in it that I have drilled and attached my snap off boss to.
Unfortunatley the snap off boss is smaller than the boss the is already on my column so i cannot bolt the two together.
Can somone in the midlands machine me a round piece of ally with a diameter of 117mm and a thickess of about 4mm or slighty thicker with do. I can drill my own holes in it for the pcd's of the two bosses, but I havent the machinery or the materials to make the piece.
I can pay cash before or on collection!
Shaun
[Edited on 12/4/09 by prawnabie]
02GF74 - 12/4/09 at 02:23 PM
if I had themachinery I would do it but do not dispair.
sounds like you need an adapter so you can drill two circles of holes for the differennt pcd.
I have something similar on mine made from 2 mm (? approx) mild steel.
It doesn;t need to be ultra price; you can make this yourself i you have a drill press. drill holes in circle with progressibely larger bit until the holes choin up or you file them so they join up = chain drilling.
same on outer.
then file to shape.
takes a bit of time but doable without specialist machinery.
see my post about trigger wheel - contact the bloke and I am sure he can laser cut you a disc for about a tenner.
prawnabie - 12/4/09 at 02:47 PM
Thanks lads, will have a crack tomorrow!
madrallysport - 13/4/09 at 01:30 PM
u2u sent
