Not sure what people generally use (zetec coil packs?), but anyone got a coil pack and connector suitable for use on my pinto?
I have a spare coil pack if you need it mate, don't have a connector though.
Rich
and ht leads too if you need em
So whats the plan mate? Do you need to source/blag the following?
toothed wheel from a cvh sierra or buy a shiny one.
crank position sensor from a newish fiesta inc shielded wire.
edis 4
Thats the plan yes.
big_wasa has a crank sensor which i need to collect, all I need now is a toothed wheel. Already have an edis.
Considering trying out the built in coil drivers in the MS. But dont know if its worth the risk...
May have a coil and HT leads in the garage you can have if you need them David but don't have tha LT connection.
I think ford use bosch JPT plugs, not 100% though. I know PSA do. I'll have look in the morning, and if so buying a new plug will make for a tidier install.
coil pack plug sorted
Ok, found the coil pack and ht leads, putting them in the post tomorrow.
Nearly sorted! just the toothed wheel!
R
