i'm short of 2 6.4mm double crimp non-insulated ring terminals for 1mm cable if anyone has any lying around.
trying to avoid pounds of p+p on something that costs pence
cheers
what is a doube crimp terminal?
I'll take a look but I don't think I have.
What I do if I am stuck, is to make some from copper pipe. It will be a better conductor but it needs to have wire soldered as the home made crimp
will not be as strong due to the metal.
It is good idea to tin the connector with solder as it stops the copper oxidising.
It'll be fine for 1 mm cable - for really chunky cable I would use proper connectors.
Give me your address im sure I have some I can pop in the post
pm sent
done.
