Does anyone have a 3/8 NPT tap i can borrow
or know a good source for a cheap one..
making a manifold for the bike carbs and want to put a water union in it.
cheers gavin
Can i ask why you are putting water though it ?
you will be the only person i know that has done it
Jacko
Or do you mean out of the head
[Edited on 7/5/09 by jacko]
It might not be water he is using the union for, just say a way to get the vacuum out to a sensor?
Or inject Nitrous?
Or to inject water into the mix to steam clean the bores?
Or a sensor?
I just checked, and I have mainly BSP taps not NTP sorry.
I have a 1/8 NTP but would be too small unless you did a typo.
Adrian
Well its possible !
I have a brand new 1 for 18 quid including postage.
Clive
i was under the impression you needed to run the water system from the waterpump to the inlet manifold otherwise the head got hot...
if i dont put the union in whwre do i run the smaller hose of the pump to ..
its pinto and will be running a polo rad..
thanks
Hi i put the pipe out of the inlet manifold to the header tank all i did was drill a hole in line with the hole in the head and welded a small pipe
sticking out to get a rubber pipe on it
Graham
This may help you
view in manifold pipe
Graham
