Due to the new ST170 inlet seals being too narrow and allowing air into my inlet.
I need to get hold of a set of old inlet to cylinder head seals, I'll replace them with new for parts if required.
ATB Dan.
i have 4 rubber joiners that go on an st170 inlet manifold to join the inlet to the bit that bolts to the engine if its any help.
Thanks but i have those, I'm after the parts that go between the head and the first section of the inlet manifold..
ATB Dan.
