hi anyone got a spare they would sell? cheers ben
What type do you need? Points,
electronic?
Geoff
i think one with points as it is the carb engine is this right? ben
Not necessarily. Ford produced a carbed version of the Pinto that had an electronic distributor and the choke on the carb was controlled by the ECU.
If you haven't got an ECU then you need a points distributor. I’ve got a spare electronic one.
Geoff
ok is it possible to have a pic to compare? cheers ben
