XE Block Wanted
philw - 28/5/09 at 01:37 PM
I need a decent XE block standard bore if anybody has has one? preferably with an HG code.
blakep82 - 28/5/09 at 01:42 PM
does it have to be from an actual xe? do you need it for something to do with the engine numbers etc? coz the ecotec is exactly the same isn't it?
liam.mccaffrey - 28/5/09 at 02:12 PM
I forgot to check mine phil will look tonight, still want the gbox?
philw - 28/5/09 at 02:40 PM
No it doesn't have to be from an XE, it can be from an XEV or an XER or from a Daewoo, i dont really care, all my blocks need a rebore which means new pistons and as i'm skint i can't afford it, the pocketed pistons i have acquired are standard bore, i will look out for a set of oversize pistons then when i get a job i can build a spare engine
