mine were all cut a bit short before i bought it (off ebay...)
thanks
hi was at my local scrappys last weekend they had 1 could possibly get you 1??? ben
ooh that would be good
it must have been there a good few years so far, might wait a bit and see if anyone's already got one in thier garage first, but if not, i might
take you up on that
ok let me know
Do what I did - take the plug apart and replace the old wire with new stuff! That way, all the cabling in the car is new and less likely to perish in
the near future, as most EDIS modules and associated parts are 10+ years old.
Yuo just need a fine metal toothpick or similar point to remove the individual pins, and then connect new wires directly onto them and place back in
the plug unit. Just to be flash, I removed all the un-necessary wiring and kept as spares in the elecrical tub.
If you can't change the wires on the pins themselves, cut them back and solder on new wires as close to the pins as possible, remembering to
heatshrink them to ensure a good seal so they can't touch the other wires.
Think i've got some pics somewhere of how I did it, will post later if I can find them easily.
[Edited on 31/5/09 by Charlie_Zetec]
ah, cool, i didn't think you could really solder new wire oto the old pins. if you've got some pictures though, that would be cool
I might have a spare one in the workshop. When I'm back in tomorrow I'll have a look.
Had a look around the workshop. Despite having 2 x edis4 modules, I only have the one plug, which is on my loom? Sorry about that.
