Hi all.
As it seems I am the proud owner of a 1.6 E-Max Pinto
, I am now in need of an ignition module for it. I have the hall-effect dizzy (I hope!), and
the red cap (so I assume it's the Bosch?)
Anyone got any ideas please?
you could just use a points type dizzy if you can find one
but if your thinking about upgrading later anyway - why not use megajolt ?
then you just need the bottom half of the dizzy to drive the oil pump and you'll have a fully programable ignition system that you can keep when
you upgrade
and you'll probably get better mpg as well
if you get the donor bits from a scrapyard (or maybe someone on here) you should be able to get the whole system for £150
btw - what carb have you got at the moment ?
Not sure what carbs I have at the moment, I've got the one that came with the engine, and another from some guy on here (called mcerd1 or
something
I don't mind going to points, but I really don't want to throw too much more money at this engine as I want to save up and buy somoething a
little more 'enjoyable'.
Originally posted by Daddylonglegs
I've got the one that came with the engine, and another from some guy on here (called mcerd1 or something)
thats off a 2.0 pinto from early sierra
