Steering Column Extension
Daddylonglegs - 2/6/09 at 12:48 PM
Still looking for a steering column extension from Sierra column to Mk2 Escort rack splines if anyone has a spare
handyandy - 2/6/09 at 12:55 PM
Hi, i have the bit that has the rubber dougnut thing on the end that slides into the mk2 rack spline, not sure if thats the bit you are looking for?
andy
Daddylonglegs - 2/6/09 at 12:57 PM
Hi Andy,
Nope, sorry, I already have that part. It's the bit from the triangle column to a spline I need.
Thanks anyhow.
JB
handyandy - 2/6/09 at 01:00 PM
ok no prob, i think i now know which bit you are after, i got mine from rally design, if that helps as a last resort.
atb.
andy
Richard Quinn - 2/6/09 at 01:09 PM
I've got a triangle to spline UJ if that would help
Flamez - 2/6/09 at 01:11 PM
There is one here;
http://cgi.ebay.co.uk/Ford-Sierra-MK2-New-G-Ford-steering-joint_W0QQcmdZViewItemQQ_trkparmsZ72Q3a1689Q7c66Q3a2Q7c65Q3a12Q7c39Q3a1Q7c240Q3a1318Q7c 301Q3a0Q7c293Q3a1Q7c294Q3a50QQ_trksidZp3286Q2ec0Q2em14QQhashZitem33524c0919QQitemZ220424046873QQptZUKQ5fCarsPartsQ5fVehiclesQ5fCarPartsQ5fSMQQsalenots upported
Daddylonglegs - 2/6/09 at 01:14 PM
I've got an old escort steering column which I intended to use as an extension. Do you think I could adapt that to fit from the UJ you have to the splined UJ I have on the rack? (The escort has splines at the lower end but I'm not sure what's at the other 'cos the wheel is still attached.)
JB
Richard Quinn - 2/6/09 at 02:51 PM
I don't know to be honest. It is the RD part for joining the Sierra upper (triangular) column to an Escort splined lower part of the column (So the RD catalogue says). Have a look at the RD website and see whether you think it would work for you. I think they are about £20 + P&P + Vat etc. It was only on the car about a month and not used on the road so how would £10 posted sound if you want it?
Daddylonglegs - 2/6/09 at 03:04 PM
That should do the job mate
I'll sort out connecting the splined end to the escort shaft somehow.
u2u sent
JB
