Radiator
jeffw - 15/6/09 at 07:38 PM
In a fit of stupidity I have just had the jack slip off the front rail of the car and put an interesting large U in the rad.
It measures 490mm x 330mm (or at least did measure) with top and bottom entry and exit with a bleed valve on the top. It was attached to the car via a right angle plate each side with 4 bolts. The car is a Phoenix.
Anyone know where I can get a replacement ?
prawnabie - 15/6/09 at 07:39 PM
If its the usualy polo rad, i have a new one you can have for 20 + postage
blakep82 - 15/6/09 at 07:41 PM
have you got any photos? as above, most likely a polo one, but just incase its not, someone might regonise it
jeffw - 15/6/09 at 07:50 PM
prawnabie - 15/6/09 at 07:52 PM
Gutted!!
omega0684 - 15/6/09 at 07:53 PM
Pooh Sticks !!!
jeffw - 15/6/09 at 07:58 PM
Is it a Polo rad then ?
gavin174 - 15/6/09 at 08:10 PM
"if its the usualy polo rad, i have a new one you can have for 20 + postage"
if jeff doesnt want it could do with a polo rad
cheers gavin
big_wasa - 15/6/09 at 08:10 PM
No that looks custom built
jeffw - 15/6/09 at 08:11 PM
crap.....
prawnabie - 15/6/09 at 08:11 PM
Speak to clairetoo, she has just fitted a rad into her fury.
Shaun
adithorp - 15/6/09 at 08:13 PM
Thats not a polo rad. Looks like a custom job.
adrian
jeffw - 15/6/09 at 08:30 PM
Cheapest option might be to get it re-cored ??
adithorp - 15/6/09 at 08:45 PM
You could just switch to a polo/VW rad. The commonly used Polo rads are...
1.1 polo rad 380x322
1.3 polo rad 430x322
SerckMarston part No's 2719517 (1.1) and 2719819 (1.3)
Those are both narrower than what you've got but there are wider ones in Golf's. They are the same layout though. I can check tommorow for a better fitting one.
adrian
jeffw - 15/6/09 at 08:47 PM
That sounds great....Do you know how they mount onto the car ?
adithorp - 15/6/09 at 09:05 PM
Each tank has 4 mounting boss' moulded on them 2 each side. Not very clear in this picture but you can just see one boss where the ally angle is mounting the fan to the rad'.
http://i189.photobucket.com/albums/z282/adrianthorp/Picture011.jpg
There's also 2 pegs on the bottom of the rad.
adrian
jeffw - 16/6/09 at 05:25 AM
So you have an adaptor plate which mounts the Polo rad to the Fury ? As you can see in the picture of my knackerd one it has two plates which bolt to the car on a mount.
02GF74 - 16/6/09 at 08:27 AM
definitely a nicely TIG welded custom aluminium rad.
have you tried to bend it bad ?
jeffw - 16/6/09 at 08:43 AM
It actually leaks from both sides...
adithorp - 16/6/09 at 08:43 AM
No, the polo 1.3 rad fitted the mounting plates on my chassis (just had to file one of the 4 holes). The ally' angle is just to mount the fan and is between the chassis mount and the rad on the same bolts.
Are your measurements the core size (thats what the makers list) or the overall size?
jeffw - 16/6/09 at 08:44 AM
Overall size. Looking at my wrecked one does the 1.3 Polo have the same mounting ?
adithorp - 16/6/09 at 09:25 AM
Not exactly but similar. It'd be easy to make an adapter. On the same face as yours it has 2 boss's on each tank.
adrian
jeffw - 16/6/09 at 09:45 AM
Looks like a plan then ....
matt_gsxr - 18/6/09 at 04:31 PM
hi there,
I only just noticed this post.
Here is a useful site for radiator pictures. You can see which one matches your dimensions and maybe even order from the site (as they are cheap).
Matt
p.s. good choice of car.
