PUSH IN DRIVESHAFTS WANTED
Gary 7 - 20/8/09 at 09:25 PM
Anyone have a pair of 27mm diameter push in shafts with 25 splines they want to sell.I want use an lsd with drums and want to fit lobro joints on the diff end.I found a pair of 27mm shafts from a 1.8 cvh but when i cut open the joint cover and removed tripode they were 32 spline and the smaller shafts i have are 22 spline.
Reading threads on here they seem to be fitted to 2 litre models.
madrallysport - 21/8/09 at 07:23 AM
I might have a set, i'll check after work for you
